Cell Phones Logo
Anonymous Posted on Nov 07, 2011
UNLOCK FREEZE - Cell Phones
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Nov 07, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
944
Points
31
You need to unfreeze from Freeze problem? it's samsung mobile?You can need to specify mobile model,?You can unfreeze it using the unfreeze code,You can get the unfreeze code for Some samsung model under European unlocking service from here Unlocking4u.com and Unfreeze it.
  • Anonymous Nov 08, 2011
    well a little cause u have to buy the code my Samsung model is gt-e- 1150 , imei -357507039325876 pliz if some can gave me the unFreeze code
BenjamineDupont
Level 3:
Master:
  • Cell Phones Master 465 Answers
  • Posted on Feb 08, 2017
BenjamineDupont
Cell Phones Master
Level 3:
Master:
Answers
465
Questions
0
Helped
206116
Points
2730
Just have a try with this applock, it can help you to boost your phone.
LEO Privacy Applock Hide Safe Android Apps on Google Play
Phone freeze unlock code Samsung F 480I
You can remove your phone freeze by unfreeze code.If you need an unfreeze code visit
Unlock-Zone.com This service can be used to unlock and unfreeze Samsung mobile phones
2answers
Samsung A707 Phone freeze unlock code
Usually you need to pay a small fee to a company like this to get the unlock code.
Phone freeze deactivate failed
Don't worry i will help to fix this Phone freeze problem.You can Unfreeze this SAMSUNG Eternity using the Unfreeze code.I would suggest the site MobileUnlockSolutions.com here you can get Unfreeze code and unfreeze it.If the Unlock code does not work ,it's a wrong code.So use correct unlock code and unlock it.Get Correct unlock code for Samsung Eternity phone from the site itself and unlock it easily.You can get Unfreeze code for South American network locked Samsung Eternity Phone .
3helpful
4answers
1helpful
Phone freeze Sim unavailable please contact service provider
Phone freeze means you enters the network code 3x wrong
If you have the original cable for this phone you can power it on without simcard.
Then get an account for the SRS online server (Unlock Samsung Online - Samsung Remote Unlock Server EN - Samsung Unlock)
now connect your phone to the computer, and install the drivers (if needed)
login to the srs server, select the correct port, and model. Now press direct unlock, and sit back. (process can take up to 5 hours). After you get "unlock done" your phone is unlocked, and the phone freeze is repaired.
4helpful
3answers
FOR PEOPLE WITH PHONE FREEZE ON SAMSUNG- the #7465625*638*code# is not needed when you have the phone freeze just follow below.
I know how frustrating this was and i got it done by myself by experimenting since everything cant be googled that easily. i figured i can help anyone out. this has worked for 5 phones that i have done my self so 5 for 5 YESS!!! This is as satisfiying to me as watching micheal jordans final shot!
any ? contact me at [email protected]
ok i figured it out. for all those people that have gotten the dreaded phone freeze om samsung propel a767 or any other samsung phone so far not sure about touch screen.
first look for a local unlocker in ur area or somewher that can provide the codes and get the unlock code and phone freeze code. mine was only 20 for both and took less than 24 to retrieve. email me for his info.
insert sim that you want to use (tmobile). you get the screen which says phone freeze. type in the freeze unlock code which was given and the press the att logo/menu button.
**YOU WILL NOT BE ABLE TO SEE THE NUMBERS YOU ARE TYPING SO KEEP TRACK OF WHAT YOU INPUT**
after you have entered number and pressed button then you will get a network lock screen. this is where you type in ur unlock code. type that in press confirm and BAMM!!!! you are now able to use tmobile sim
try to flash ur phone then give it the unlock code!!
my samsung z500 hang after 1 min it turn on. keypad and other thing does not work.
Nov 07, 2007 • GPS
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
