Hi Jeff, W/D here.
Spray arm blockage is caused by particles of debris plugging the spray nozzles and/or the directional slots. They are easily cleaned out.
If you can, remove the arm and take it to the sink. Back-wash the nozzles and slots towards the center hole, flipping the arm over occasionally to pour the debris out. You can push the debris backwards back up into the arm with a toothpick, and continue to wash as described. This will usually correct the problem.
Best regards, --W/D--
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
