Hi check to make sure the antenna is connected correctly. try tunning the channels manually and if they come up you can save them one at a time. Also try moving the antenna to a different location. make sure the TV is set to scan on the same input that you are connecting the antenna. If all that fails ou might have a defective tuner board.
You can get parts for this tv at www.interliquidparts.com
I did check all connections and the antenna, it worked fine before the re-scan. A friend at work has the same set and he also did a re-scan and had the same problem. He found that if he entered the actual digital channel numbers rather than the local channel numbers the TV would pick up the channels. Mine also worked the same way so now we are back to high def but have to have a translator paper to map the local channel numbers to the physical channel numbers.
