You are refering to Reed switch or Sensor switch or Speed Sensor? please indicate.
Some equipment can have the safety switch when you remove the Hood as security measure, for to avoid the machine goes on or Start ON .
Please specify.
sincerely.
i a,m referring to the little magnetic key that you stick into the slot across from the bar you have to hold on to. The manual calls it a "magnetic safety key" and when i turn on the treadmill it says reset safety switch
Locate the reset switch on the underside of the treadmill console
Usually the button is large enough to trigger with a pencil eraser or Q-tip.
sincerely. e.cuadra
underside for the console, you can touch with pencil or Q-pad,sincerely.
