Windows setup could not configure windows to run on this computer's harddrive
Hey brother,
Recently, I was also facing the same problem in my laptop. I was very worried and tried lot of things but nothing worked. Then one day, I was researching online how to fix this issue.
After a long period of surfing, I came across an article, they have described some steps on how to resolve this issue.
I followed step by step instruction and my problem got resolved. So, you can also go through that blog and just by following few simple steps you can fix this issue.
Follow the link to read the blog - https://www.microsoftwindowssupportnumber.com/blog/windows-setup-could-not-configure-windows-on-this-computers-hardware/
Take 2 minutes out to mark this answer helpful, if this option works for you.
Cheers,
Luke Carter
Go into the BIOS and activate "Load Fail-Safe Defaults". If you HDD is SATA set the SATA controller to compatible mode in BIOS.
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Once all these steps are completed make to change the boot device to hard drive from CD rom.
