SOURCE: brew group on saeco odea giro wont go back into machine
try to put in the dregbox to the machine, close the door and power on the machine. When the machine not make any noise, open the door and put in the brew group.
SOURCE: Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
SOURCE: odea go dumps shot
Try this remove the brew unit and clean the screen, the red light is saying that it cannot push water through.
SOURCE: Saeco Magic Comfort Plus dumps
From your description we understand that your machines vital parts like water pump, grinder, group and gears, boiler, electronic board all are working fine since there is a final result the coffee. The only problem you face is that due to long time use some coffee liquid have dry out layer by layer and have goggle the Teflon pipe of the plastic unions so the coffee cannot be deliver through to the coffee tap and as a result is ending in the coffee drugs drawer. So you need to disassemble you machine and remove the Teflon pipe which is after the coffee croup and by using a thing metal wire like a paper clip or similar you can check the pipe and the plastic unions to find out where they are goggled from dry coffee. You can immerse them in boiling water from some minute so the dry coffee to dissolve and be removed completely. By this chance you can remove also the coffee group filters and also clean them with hot water. We have here below the link with exploded parts view of your model which will help you find the parts and understand how your machine is constructed. http://www.partsguru.com/user/E003039-ed1.pdf Also you may now you don't have any problem but we suggest performing at least once every month de-scale so to keep your machine in perfect condition. Also if you might need nay part replacement you can even order it from the same side in this link
