SOURCE: Krups KM7000 won't brew
Your heating plate is your hot water heater, and most likely failed. Krups replaced my whole unit.
SOURCE: KRUPS KM7000
Check to see if your heating plate warms up, if it doesn't then your water heater/heating plate has failed.
Check to see if your heating plate heats up, if it doesn't then your water heater/heating plate has failed.
SOURCE: Got a Krups KM7000. Coffee grinds but no water to
Check to see if the heating plate warms up, if it doesn't your water heater/warming plate has failed.
SOURCE: Krups KM7000 grinds but won't brew, warming plate
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
