Stoves 720EF Electric Double Oven Logo
dean mcnulty Posted on Nov 05, 2011
Ihave a minder shed alarm (4 button model) the batteries ran out and i dont know how to reset it any1 help!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
300
Points
Factory Code settings 1234, To change the factory code press button 1 for 2 seconds, wait for 2 beeps, now enter your new 4 digit code, you will hear a further 2 beeps to confirm the new code. If the battery is removed the code will revert to the preset code(1234)
1helpful
Stoves 900 ef heritage doubel oven. I cannot seem to get the oven to work as my daughter has fiddled with the clock which has to twisting knobs - one saying cook time and the other saying start time. I...
For the 720ef , this is what you need to do. Hopefully this will translate to your 900.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
To reset the cook time, use the plus and minus buttons to set it to zero.
To cancel the automatic setting and return the oven to manual operation, press the COOK TIME and READY TIME buttons simultaneously.
I hope this helps.
4helpful
How do i set the clock
Just moved address, new house has a Stoves 720 EF built in oven.Model 059040437. I can't work out how to turn on the grill or set the timer, don't understand what any of the symbols on the front left next...
I don't know if this will help. For the 720ef , this is what you need to do.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
I cannot turn on the bottom oven on my stoves and I believe it's because the clock is incorrect and I don't know how to change it.
There are five buttons. from left to right they are Minute Minder, Cook Time, Ready Time, Plus, Minus.
To set the time of day press the Cook Time and Ready Time together and then use the plus and minus to set the time. Use the Minus button alone to change the alarm tone.
To set the Minute Minder, press the button and use the Plus and Minus to set the time period. To cancel use the Minus to ge back to 00.00.
32helpful
Simpson Apollo can't set clock so oven won't work
Stoves 444445060 user manual needed how does the timer work
I don't know what model oven this relates to, STOVES may be able to help you if you need to take this further. For the 720ef , this is what you need to do.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
7helpful
2answers
Set clock for stoves efa 700h
Try this. For the 720ef , this is what you need to do.
How do you set the clock on a stoves 059040411 oven?
60helpful
2answers
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
The top and fan oven keep going off because of the timer. I dont know how to get rid of the timer a I never use it. But I donbt want it to cut out th overn which it is doing. Hel,p and info please
There are 5 buttons next to the clock. From left to right they are:-
Minute Minder, Cook Time, Ready Time, Plus and Minus.
It sounds like the timer needs setting back to manual, so to cancel the automatic setting and return to manual operation, press the Cook Time and Ready Time buttons simultaneously.
To cancel any remaining cooking time left on the clock before the alarm sounds, press the Cook Time and Ready Time buttons simultaneously.
If you are interested, to set the time of day, press the Cook Time button and the Ready Time button simultaneously. Then use the Plus and Minus buttons to set the required time.
To set the Minute Minder, press the Minute Minder button, then use the Plus button to set the required time. You can cancel the minute minder at any time by pressing the Minute Minder button and the Minus button until the display returns to 0.00.
To select an alarm tone, press the Minus button to listen to the first tone. Release the Minus button and press it again to listen to the second tone etc. Releasing the Minus button after the tone has sounded will automatically select that tone.
Hope this helps.
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
