there a small bolt missing on the front of my kawasaki 1500 nomad that r not there and a little fuel come out from time to time do u no what it call so i can get another one to put there ? and after changing the oil bike wont shift gears help ? only first gear
TO ALL VN1500 OWNERS....This once happen to me, I went to the garage to start the bike "Nothing ""The first thing is the lights are bright but no turning over,Next you think the solenoid is kaput but the answer was very simple and the fix takes 30 seconds.. Do not take the bike to bits looking for other problems and look at the clutch leaver and you will see some wires going into a plastic shroud going into the switch in the clutch leaver, Make sure this has not popped out if its connection as it some times may do after a few years due to constant turning on the handlebars, When this is not connected you will have a bike that will not fire up but comes alive and you will hear a clicking noise but this is from the engine carb area and every function of the bike will work but it will not turn over, Worth looking at and saves sixteen quid for a starter unit you never needed.
I have a 99 nomad and found a tank that is bigger to fit but they wanted 800 american for it. found an add on from a place called tour buddy.com for 200 with all the fittings. fits on the back where the luggage rack goes. 4.5 gallons. I love it.
Offhand would suggest a rebuilt/clean of the carbs. A temporary workaround would be to switch off the fuel petcock, remove the fuel hose, partially drain the carbs and spray into the fuel hose (going into the carbs) injector/carb cleaner. Reinstall fuel hose, turn on fuel. Remove the air filter and start the bike. After warmup, rev while spraying injector/carb cleaner into the opening where the air filter should be. Get a hard paper/board (such as a folder) cut to a size bigger than the air filter but would fit inside the opening of the airbox. Rev/pump the bike slowly building the RPM at about 4~5K suddenly cover the opening (with the board) to fully choke the carbs while maintaining throttle. Before the engine dies, remove the cover. Spray again while revving. Repeat choking/spraying several times. The idea is for the vaccum to draw the clog/blockages.
Pls post back result(s). Good luck and Thank you for using FixYa.
