Be like that other Linksys router model, Linksys WRT160N router is always unique because of their wild, future-oriented functions and even smaller size.
You can call on the Linksys support number in order to get help from the expert to start running the router again. If the number you have dialed is not giving any response, you can go to the Contactforhelp to acquire the alternate contact number of technicians. Linksys setup customer support phone number Technical Service USA
SOURCE: Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
SOURCE: How to Upgrade the Firmware on a Linksys Router
I have update the fireware of linksys router WRT54G ver.2.2 by wireless.. Wrong move.. Then it stop loading.. now I can not get in to the router even i reset the router.. what can i do to have it back..
SOURCE: cannot reset router after Firmware upgrade failed
you may have bricked it... there is a solution that i've successfully done i'll get you the website
SOURCE: How do I activate WPA on my Linksys wireless router?
Your users guide will better explain this; however, if you do have any other questions, please let us know.
Here is a link for your users guide online:
http://downloads.linksysbycisco.com/downloads/WRT160N_ug,0.pdf
You will find important information in Chapter 2 and information for setting up WPA in Chapter 3 Under Wireless > Wireless Security
Hope this helps.
SOURCE: Linksys wrt160n drops connection
Have you verified the DHCP lease of the external and internal IP? Could be a case where the issued IP is renewed and breaks comm, although this should not happen.
