The printer wont print. it has status:offline showing.
i have unplugged the cables and put them back but still nothing. Please help.
The printer status showing offline is more then likely a computer issue then the printer. On the printer, use the menu to select "reports" and then select the printer settings report. If the printer prints the report, then the printer itself is working, and it is a communication issue between the printer and the computer. If you are connecting to the printer with a usb cable, then try moving the usb cable on the computer to another port. If this does not work, try deleting and reinstalling the printer.
An alternate fix would be to go to the Printers and Faxes window, locate the icon that represents the 1815 printer, right click it and select "Use Printer Online".
I have the same problem with the same printer and It is not connected with a USB cable. I right clicked the printer as dulvaryenai suggested, but there is no "Use Printer Online: option. nothing even close to it. Please help!
How do you have it connected and what operating system does the computer have that you are attaching it to, trying to print from?
If something goes wrong with your Dell printer you try to fix it on your own or you take local solution which you often find costly and not 100%. So, we advise that you can get called "One Search Point" provided by us. We offer a direct number that you can call and talk to the Dell representative on the phone and discuss the problem with your Dell printer. Within a minute, your problem will be solved and if it requires further support then you are provided that as well
Dell Printer Support Phone Number.
https://www.onesearchpoint.com/dell-printer-support-phone-number/
Why The Dell Printer Offline Error Occurs?
Ā§There can be issues with Printers and Devices in the control panel thereby leading to the problem at hand.
Ā§There can be issues with the Printer Settings resulting in the particular error.
Ā§Issues with the Printer Driver can also cause this Dell-related error code.
Ā§There can be some connectivity issues with your Router or Modem that are probable causes of the Printer Offline error code.
For more info Do Visit Us: Dell Printer Offline
My DELL printer was also not printing anything, I tried a lot to fix that but unable to fix. At last I got this link http://www.printer-techsupport.com/Dell-printer-support.html I just visited and made a call on their toll free. I got instant help from a certified technician to fix my printer.
You have spent to much time ending up in the
Dead Letter Office Coffee.
Steve
I am hooked up to Devon IT Workstations - 4 through a community peer to peer network the cartridge was just replaced, It is stacking up print jobs, how do I make this thing print? Do I need a usb flash drive? cord? what?
MY 1815 printer show "No paper" though there is paper, how can I fix the problem??
