Toshiba Satellite A205-S4617 Notebook Logo
MR J WEST Posted on Nov 04, 2011
HOW TO RESET MY TOSHIBA A205-S804 BECAUSE IT WONT BOOT UP
4 Related Answers
florin_decad
Daniel Florin
  • 203 Answers
  • Posted on Jan 18, 2009
SOURCE: toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Anonymous
  • 33 Answers
  • Posted on Jan 20, 2009
This sounds like a file error (but not positive). My suggestion would be to change your boot order in bios ( a must since this is a Vista machine and CD-ROM is always set as one of the last. Hit F1 (or maybe F2?) when first turning it on to get the bios screen. Go to the Boot menu and set the CD-Rom as the first in order, then hit F-10 to exit and save. Be sure to put in your vista op system cd in your rom drive and see if you can't do a system recovery with it. I know that it was an option with XP.
Preston Bailey
  • 24 Answers
  • Posted on Nov 19, 2009
SOURCE: my toshiba a205 s5804 is asking me a bios password
There is a known issue on this model (A205 and A215) and Toshiba knows about it. A password can be automatically be set by the computer and will need to be removed and have the BIOS updated so it won't happen again by an "authorized service provider." You can locate your closest Toshiba ASP at support.toshiba.com This is a known issue and Toshiba knows about it. You should get this covered at no charge if you take it into an ASP, make sure to verify this with the ASP and take it somewhere else if they tell you it will cost you anything. Toshiba will cover this till December 31st 2010.
Toshiba Customer Service # is 1-800-457-7777
Anonymous
  • 6 Answers
  • Posted on Dec 03, 2009
remove ac supply and battery from the laptop.. and press power button for atleast 30 sec.. it reset the CMOS memory.. this is what toshiba technical support person told me to do when i called to them way back..
How to fix TBX Error on Toshiba Satellite a205-s4707
Take out battery from it, and re-insert it after 15 minutes or so. This must make it a hard reset. If it too doesn't help you, make sure there is a software corruption has been occurred. Re-install the O/S is the only solution. Electro help
tip
Motorola S804 Manual Download
Download Motorola S804 Cordless Phone Manual
Have you misplaced your Motorola S804 Cordless Phone Owners Manual?
Would you like a digital, searchable, pdf version of the Motorola S804 Cordless Phone Users Guide?
Follow this link (& click FREE) to download a pdf version of the Motorola S804 Cordless Phone instructions.
I hope that helps.
_______________________________________________
on May 09, 2010 • Lands Phones
Toshiba a205 s7466 will not turn on replaced cmos battery what next?
use old battery first try to boot
if your system is boot run bios update from intel.com
then change new battery
else run bios flash from chip level service provider
2answers
Toshiba a205 wont enter into recovery mode
with the computer off. start by having it plugged in. now press and hold down the 0 (zero) key. while holding it down press and release the power button.. as soon as you see it power up release the 0 (zero) key. this will restore to out of box state. it will take aprox and hour. You wont have to do anything just let it run the restore..
2answers
Toshiba a205-s5000 forgot dmin9strators password. dpn't want to loose data help
Go to the link below and download the cd/iso file of KonBoot. Make a cd and boot from it on your locked puter. It breaks any windows password and you can reset.
http://www.darknet.org.uk/2009/06/kon-boot-reset-windows-linux-passwords/
Cya
Marcus
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
