Well you need to log in as administrator reset the IP address the mask and gateway. it is still on the old net work and was set as static IP address which mean it not set up for DHPC
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: bizhub C450 error (C-0212)
I've just had the same problem - empty the LCT and close it. Open and close the front door of the machine. This should clear the code (it worked for me). Then reload the paper in the LCT as previous
SOURCE: BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you
need to use the option that scans to SMB, that sends the scanned
documents to your computer on the network. You can then process
the documents on your computer with the OCR software program so you can
edit the finished documents. I did not see anything that
indicated the Bizhub had OCR software capabilities built into the
unit. Regards, rcampsr
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
