Vtech Kidizoom Digital Camera Logo
Anonymous Posted on Nov 03, 2011
Is there anyway i can retreive the pictures from my sons vtech camera's internal memory. My daughter accidentally deleted them
Level 3:
  • Vtech Master 17,130 Answers
  • Posted on Nov 04, 2011
Vtech Master
Level 3:
Answers
17130
Questions
0
Helped
3631848
Points
52372
1helpful
Accidentally deleted pictures, any way to retreive?
If the pictures were on a memory card and you haven't done anything with the card since then, you have a good chance. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the card into a card reader connected to your computer and run the program.
Cant delete the memory from my daughters vtech camera
I plugged the camera into my mac and used the disk utility on OSX to erase the internal memory of the camera. I am sure you could get / have a similar utility for windows.
Some pictures seem to have been deleted from the memory card and I can not figure out how to retreive them from internal memory
The delete (garbage can) on all these cameras should be used sparingly it's been the cause of more problems then enough but it's there and people use it, The memory card should be formatted every time the pictures are downloaded to the computer. That way the memory card is clean and fresh for the next series of new pictures. Now the pain about getting the pictures from internal memory to the computer is another little annoyance. Each picture from the internal memory has to be loaded to the removable memory card one at a time then when all the pictures are on the removable memory card they can be downloaded to the computer and the internal memory cleared/deleted. Cheers from Robert in Canada
Pix lost from Kidizoom Camera
The instructions say that you will lose your pictures stored on the internal memory when you remove the batteries. Use a SD card instead of the internal memory, or download the pics from the internal memory before changing the batteries.
Loss of Photos
Remember, if you're in the photo album if you accidentally hit the delete button with a picture on the LCD screen...it's outta there.
Accidentally deleted photos from internal memory of my Kodak came
Hi!
Let's try to save your son's halloween pics.
There are a lot of recovery software that you can use to recover deleted files - specially pictures. You can try to use Zero Assumption Recovery. You can download the software at this site:
http://www.z-a-recovery.com/download.htm
It's a free software (you do not neet to pay to use this), and it's easy to use.
Here are the steps that you need to do:
1.) After you install this software, connect your camera to your PC (do not insert the memory card). Turn on the camera, open the Zero Assumption Recovery software.
2.) Click Next. Select "Recover images from the digital camera.." and click Next again.
3.) Select the Physical Device - select your camera , click Next. [grab a cup of coffee since retrieving the files may take some time depending on the size of the memory (",) ]
4.) After retrieving the files - select all the files that can be recovered. Click Next.
5.) Select the button on the right side (close to Destination) and select where you want to save the files. Click "Start revovering files".
That's it.
I hope that helps.
Good luck and have a nice day!
3answers
Retreiving deleted pics from camera
It can retrieve all data from the camera memory and also from the memory card that you have there, if you want to make sure you can go to a photo center and they can retrieve all your deleted photos from the internal memory of the camera and also from your memory card...
Hope that helps..............
Retreiving accidentally deleted pictures
Once you delete anything off scan disk or flash drive they are gone forever ...
Sorry about your loss of photos
Internal Memory/Software? Deleted Can't Put Pics On To Pc
you can try downloading a data recovery program and you just may be able to get the software back try easy recovery
Top Vtech Cameras Experts
ZJ Limited
ZJ Limited
SmartAviator
SmartAviator
john h
Are you a Vtech Camera Expert? Answer questions, earn points and help others
