Copystar CS-1650 All-In-One Laser Printer Logo
Posted on Sep 25, 2008
Copystar How do I reset my printer to default
Anonymous
Level 1:
Scholar:
  • Contributor 45 Answers
  • Posted on Sep 25, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
45
Questions
0
Helped
35043
Points
82
Press the Printer key.
Use the up / down keys to find "Menu", then select with the Enter Key.
Use the up / down keys to find "Others", then select with the Enter Key.
Use the up / down keys to find "Printer Reset", then select with the Enter Key.
Use the up / down keys to find "OK", then select with the Enter Key.
Copystar CS-2050 cutting off edges when copying or scanning
Check your default paper size. It may have been set for A5.
1helpful
My copystar printer is showing error code c6040
This is fuser unit error code, you can try reseting it by running mode 163, if it doesnot work you need to replace the fuser unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
How do I reset the drum counter on a copystar 2050
press 1087 twice, enter maintence mode press 251 and reset to 0
Ii want to set the password kyocera 2550
Push the System Menu/Counter Button
Using arrow keys find the Machine Default-press enter
Use the factory set PIN (should be 2500)-press enter
Arrow to PIN# change-press enter
Using key pad choose new number-press enter then press the reset button
3helpful
2answers
Getting a c6400 on my cs2550 copystar this all happened after a power outage
reset it with... 10871087 then type 906... press start then reset then start
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
1helpful
How to reset gs-1820 copystar to factory default
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
then use the arrow keys to get to u020
and select and then run the reset...
these machines do not automatically restart so you will have to flip the power switch manually to reset the machine
4helpful
2answers
Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
The password is 6482, this is the admin password for all copystar machines.
Thanks for using Fixya
Reset Scanner Password for Copystar CS-1650
yes you can !
turn OFF the copier and unplug the power cord and the network cables!! Take off the scanner board - there is a jumper to reset the scanning system to default factory settings. Install the scanning system and power the copier. Wait till is Ready to Copy + 2 minutes. turn OFF and unplug the power cable, restore the jumper on the scanning system board. Put it back and power up.
Copystar CS-1810
You need to run sim U163 to reset fixing heater problems. Press and hold stop, start, and left exposure key in that order. Release and press stop again. Use zoom keys to enter 163, press start. Exit the mode by entering 001 and start, or power off/on.
Resetting code on a copystar cs-1620
what code? many codes to be reset such as 1087 1087 then enter163 to reset fuser. you need to know what your resetting first, some machines used 096. let me know what you resetting. rrralf
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
