SOURCE: Memory Full
What size is the memory card. What picture size has the camera been set to? Check out your Manual for the images sizes viz a vis memory card capacity - and come back
SOURCE: upload pictures to memory card
This model doesn't allow you to upload photos from a PC to your memory card whilst the camera is connected to the PC. You will need a memory card reader.
SOURCE: exilim ex-s770 - "this file cannot be played"
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
SOURCE: copying pictures from computer to memory card
vista is main problem are you viewing the picture before you move them vista has problem if u open it 1st before coping moving etc etc it does what u mentiond b4 either shut the program u are using to view with down before u transfer them
SOURCE: when i take a picture it wont save on the memory
THe memory card is either to large for the camera, or needs to be formatted. Put the memory card in a laptop or other card reader and inspect what is on it; save the contents and then reformat the card for the camera by running format.
