SOURCE: Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
SOURCE: how do you remove stones from the grinder of a
Disassembly of the grinder is most likely due. There are springs and ball bearings in there so be careful not to lose any parts. I learned that the hard way. I can send a pictorial, written in German, but helpful. e-mail me at [email protected].
Mike
SOURCE: Describe your Jura Capresso Impressa E9 Espresso
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
SOURCE: My Jura Capresso, Z5 is
Hi The connectors on capresso machines are very tricky. The reason for the leaking could be to do with the seals. Take it apart and make sure all the rings and pressing clamps are in the right place. Also take a good look and on your hot water tank, and the pressure relief valve in back of machine. Also it is recommended that the Jura coffee machines to be serviced every 2 years. Thank you for contacting fixya.com
Please get back to us if you have further query else please accept the suggestion.
