Spark plug, air filter, gas is good
SOURCE: Little spark
check the gap on your plug. .030 is what it should be. also make sure that your
kill cable is working properly and not grounding the engine out.
the gap for you magneto should be set to .010 to .012
loosen up the magneto insert a standard business card or 3x5 card
then turn the flywheel so that the magnet on the flywheel pulls the magneto into it. then tight the magneto mounting screws down. try spark now. always use fresh gas. -no-water- if in doubt throw it out.
gas is BAD after only 30 days.
SOURCE: How do I clean the
the fuel line if it is dirty you should just replace it you can get it at homedepot or ace hardware . your spark plugg gap should be the thickness of a match book . and the air filter should be replaced every year if you use it in a dusty environment maby every couple of months .
