No ice.
Pout about 2/3 cup of water into the ice maker . If it dumps but does not refill , replace the water inlet valve ( the piece the wall water line connects to behind the refrig ) . Also check the tube which fills the ice maker as it will freeze up , not letting water go into the ice maker . This is also caused by a bad water valve .
If the ice maker does not dump the water poured into it , replace the ice maker .
Also , check that the coils are clean under the front of the refrig , as this will cause slow ice production and can cause the ice maker not to dump due to too warm of temperature . Ice maker has to be 5 degrees to operate .
