Does anyone know if the HTC G1 Sync with outlook and other pc programs?
I read that there are No PC syncing.
I want to buy this phone but without syncing it will be useless for me...
Thanks
Mickey
Load http://oggsync.com into Outlook and it will sync to Google. Then use the G1 native google sync.
- Shawn
At the moment there is no Exchange support for the G1 phone, Fortunately though, with it being Open-Sourced OS i can guarantee some person and/or company is Creating a program for the phone which allows Push Exchange support for outlook etc ! as it is a widely used program.
There are already programs created which allow the Synching of Outlook Contacts and it Does support Pull POP3/IMAP email
Hi @fmarcoux260496. I have some troubleshooting steps for you that may get HTC Sync working again!
On your PC, go to Control Panel and click "Add and Remove programs" in Windows 7 and Windows Vista or "Programs and Features" in Windows XP. Double click HTC Sync and choose "Repair."
If Repair does not work and you still get the error, reinstall HTC Sync. To do this, click on "HTC Sync" and then click "Change" or "Change/Remove" and follow the on-screen instructions. Do this for "HTC BMP USB Driver," "HTC Driver Installer" and "Adobe Air" as well. Once that's done, go to http://www.htc.com/ca/support/amaze4g-videotron/downloads/ and download and install HTC Sync. It is under the heading, "HTC SYNC 3.0.5579 FOR HTC AMAZETM 4G ' 15.12.2011". Complete instructions can be found by clicking "More." This will also install the newest HTC drivers and the newest compatible version of Adobe Air.
After you've finished installing HTC Sync, connect your phone to your PC via USB. Select "HTC Sync" from the "Connect to PC" pop up on your phone, and the phone will search for and open HTC Sync!
If you're still seeing the error message, disconnect your phone and perform a soft reset, and then re-connect the phone to your computer. To do a soft reset, just turn the phone off and remove the battery for one minute, then re-insert it and turn the phone back on.
If you still experience problems, I recommend you contact my teammates in Customer Support. You can find their contact information at http://htc.com/support
Please check in and let us know how that helped!
