you have only restated what i already tried. come up with a new idea or refund my $35 please. jt :)you have only restated what i already tried. come up with a new idea or refund my $35 please. jt :)
You can't post conmments that contain an email address.
Unfortunately, I do not have a schematic diagram. However, having delt with these kinds of problems on TVs, stereos, VCRs, etc., I would say, over 90% of the time, you won't need a schematic to figure out the problem. Chances are that a solder joint slightly cracked, and possibly broke a trace. I would inspect the circuit boards carefully, especially the legs of the transformers, relays, and capacitors. Unless you can find another owner, the schematics are usually hard to find, and when you do, they can be expensive, so I would try spotting some physical damage before expending the money for a schematic. You only need them maybe once every 10 or 20 years on these machines, normally. Good luck, hope you can see and fix the problem!
#1 check the batteries in your remote,#2 if this is a new system contact the the dealer(let them handle it)i'm sure they will make it right.(what i'm saying,is don't void your warranty buy trying to fix it your self.enough said!thanx for using fix-ya!!!
first pull out the power transistor then biased the output terminal. base,emitter have dc volts .4 to .5 collector to emitter have full voltage. if this voltage are in ur pre amp buy new trasistor
