SOURCE: i do not have any
First, the obvious, check speaker jacks, and speaker power button...then, go to control panel and click "sounds and audio devices"...make sure the "Mute" box is un-checked and volume is turned up..if all of this is o.k., then, go to control panel, Click "System" and then "Hardware" tab , then, "Device Manager" , check to see if you have a yellow yield w/ exclamation point..if you have this, it is probably a driver problem, it will probably need to be re-installed.
SOURCE: L91a monitor
http://www.hyundaiq.com/Eng/DownLoad/MonitorDri/View.asp?page=1&SchSel=&SchStr=&idx=87&V_nm=30
Use this driver to tune the image
SOURCE: lcd monitar
If you use OS Windows, try this :
Start Menu - Control Panel - Display (double click) - in tab Setting - read this sentences :
Drag the monitor icons to match the physical arrangement of your monitor
Click in the right-mouse on screen 1, click in "Attached". May be you can see LCD. Or, try this : you need monitor CRT of computer. Plug in to slot VGA inside your laptop. And restart your laptop. See in your monitor CRT. If your monitor CRT will see your display and your LCD laptop didn't see anything, it's that mean for your laptop is broken in video display onboard. Replace new one of your laptop mainboard.
Or, press button of 'Fn' and 'F3', will be switched between your LCD laptop or other monitor in your slot VGA.
SOURCE: monitar goes off after afew seconds, but indicator
Hi Update the graphic card drivers before that try to boot the system in safemode and keep it under obeservation if works then its an drivers issue so uninstall display driver and reinstall it agian.
SOURCE: sir my quary is that
Look for shorted out transistors and blown fuse, it is almost the same as 1740, also inspect the caps.
http://s807.photobucket.com/albums/yy352/budm/HP%20L1740/
