My Sharp OZ-730 died almost two years ago, and I can't bear to give it a decent burial! I've tried replacing the batteries (obviously), resetting, the hint about resetting while holding the start button ... Should I just give up? I kept checking eBay for a replacement and gave up - now trying again.
"Desperate in Vancouver, Canada"!
When you held the start button down and pressed the reset, did you get a message appear ? as per the manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000002412.pdf
SOURCE: Sharp Wizard OZ-730
Hi, I has this same problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
SOURCE: forgotton password for Sharp OZ-730
The start key is the same as the power button. I pressed this down while doing the reset. Then I let go the reset while still holding down the power button. Worked like a charm.
SOURCE: Been in Iraq for 2
This isn't really a solution, but be aware that the password IS case sensitive.
SOURCE: Replace battery in Sharp OZ-8000 pda.
unscrew 3 little screws at the bottom cover using jewelry phillip driver-remove the cover- you will see further instructions inside the cover. This model requires 5 batteries CR2032 (4 for main memory-1 for backup memory)-Hope it helps.
SOURCE: i have an OZ-730 sharp wizard and it will not turn
Be sure the batteries are in correctly and are good, be sure the battery switch is back to the "normal position" - also it may have to be reset to work again - here is the instruction manual for doing that , page 7 chapter 1:
http://www.promsoft.com/dev/oz700sdk/oz7xx_manual.pdf
