My friends 12v golf battery as got reverse polarity,he connected the wrong charger leads to the terminals posts,can he undo the process,!if so could you please explain how.
Reversed polarity,check fuses. check the system for burnt wires also !
Always hook up your battery terminals correctly, as the alternator may be damaged if the battery is hooked up backward. jump start car, if it will. there should be at least 13.7 to 14.2 volts at battery posts while its running. if alternator is ok.
