Watches Logo
A
Anonymous Posted on Nov 01, 2011
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work. Unable to get day of the week set and Forecast doesn't work. Where can I get the setup instructions? Thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 02, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1480
Points
0
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
1 Related Answer
Anonymous
  • Posted on Jun 01, 2011
SOURCE: Ultronic clock, humidity & temperature.
This clock keeps track of the temperatures for each of the last 12 hours. So on the bottom, you'll see the temp at 12 hours ago (-12), 6 hours ago (-6), etc. On the left side, you'll see the temperature in Farenheit go from +5.4 to -5.4 from where it is currently. So if the temperature is 70F degrees right now, and it was 65F degrees 12 hours ago, then it'll show -5 in the first -12 column. It will always be at 0 for the current hour on the right. The scale on the right is in Celcius so it does the exact same thing as Farenheit.
I live in Arizona. Which city should I use to set my global atomic watch to sync.
Atomic clocks have antennas that are directional and reception may be improved by turning the antenna to increase signal strength. Place the radio controlled clock along a wall or near a window that faces towards Fort Collins. Locate atomic wall clocks at least 4-8 feet away from computer monitors.
Atomic Clock Synchronization (weathershack.com)
How to set ultronic weather clock
Select "change time zone" and press to remove the "automatically adjust clock for daylight saving time" symbol to automatically update the clock when daylight saving time is applied.
Oct 01, 2018 • Watches
How do I re-set my CLOK TCR338 to not read in military time?
heres an answer another question had that might assist u in some way:
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected]. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Dec 05, 2014 • Watches
Ultronic clock instructions
Need help to set week day and 12 hour day instead of 24 hour day on Ultronic weather clock sent to me without any instructions, can you help or tell me who to contact to find out how to set up this clock?
Dec 10, 2013 • Watches
Where and how can I buy Mondaine meeting point railway table clock
Set up a pay pal account or just use your credit card then buy on-line
http://global.rakuten.com/en/store/trendone/item/10029501/
Need ultronic ws-9 instruction manual
If not found with the model and Google try to find the website for the maker.
Nov 05, 2012 • Watches
21helpful
Ultronic clock, humidity & temperature. How does one read the "Temperature Trend" scal on the lower left of the screen. There are three scales shown and the indicators on the scale keeps...
Mar 01, 2011 • Watches
1helpful
Tinkerbell Neon Light Wall Clock Where can I find a replacement neon light for my Tinkerbell clock?
I would contact Disney at the following link:
http://aimg.disneystore.com/content/global/guest_services10/contact.html
My good guess would be that it will be cheaper to replace the entire clock but I would contact Disney. Good luck.
97helpful
5answers
Hi i have an alarm clock digital it is called an ascot by kripplwatches the serial number is... po5623 type .. hsd110b it is only a cheap thing but i like it and can not fiind instruction manual can you...
to set the time: switch to timedisplay and hold the "S" key for three seconds, then adjust with the arrow key´s
to set the date: same prcedure as time but first switch to the date display
Jan 03, 2010 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
