Question about Netopia 2200 Series (2246N-VGX) Router (2246NVGX)
I can't access to my account from my iPhone. When a did install this router in my office desktop I did not have any other wireless device @ home,the installer told me that in the future i should be able to run any of this devices,now with the iPhone i did tray to connect and the un & pwd do not work.
3 Suggested Answers
SOURCE:
compucure
  • 61 Answers
SOURCE: Cant get Wireless card to connect to netopia wireless router
There are some things you might try.
The Belkin card will come with third party software you can disable this utility by right clicking on the icon in the Taskbar and choosing "Use Windows Zero Configuration".
Then you will need to go into Control Panel >> Administrative Tools >> Services >> Wireless Zero Configuration >> Right click and check that the service is starting automatically >> click on Start >> Apply - that should then detect your wireless network and the internet.
Posted on Feb 25, 2009
SOURCE: Netopia 2247 NWG can't find Atheros AR5007EG WLAN
ok heres the solution.
goto start,control panel,performance and maintainance,administrative tools,services.
Scroll down to bottom to WIRELESS ZERO CONFIG,double click and click start.
now exit and wait a minute and your limited or no connectivity should change to connected,
let me know if this helps,
Patrick.
Posted on Jul 15, 2009
Wirless isn't picking up on device
i dont get your problem, but if you want to access the desktop of the other device, you need to enable remote desktop.
however,if you want to access the drive of the other device,you need to configure a mapped network drive.
Feb 15, 2013 | Cisco -Valet Wireless Router
I cannot get a wireless connection with my iphone so backups don't happen
You probably need to make sure that your iphone and your router are both using the same 'standard' of wifi (wireless 802.11b, 802.11g, or 802.11n) The older 'b' and 'g' standards use 2.4 GHz frequency - The Newer 'n' standard can use 2.4 GHZ and also 5GHz for faster performance - I think the iPhone asks you to choose which frequency you want to use rather than asking you to type in 'b', 'g' or 'n'
Nov 12, 2012 | Linksys E900 Wireless N300 Router
HP office jet6500a is not detected by ipad2. Using an arris 550 modem and linksys wrt110
sounds like an Ipad problem not a router problem. Apple products (ipad, ipod, iphone) are very tricky to set up on wireless devices as they require settings router that windows devices have no problem with. I would seek answers from apple.com
Sep 24, 2012 | Linksys Wireless-G WRT54G Router
How to turn on wireless switch on a desktop
I've never seen a 'switch' on a desktop to turn-on wireless, like there are on Laptops/Notebooks.
Usually it is either a device that is install in a slot in the PC, or it is a USB plug-in adapter. There ARE some motherboards with built-in Wireless ability, those can be turned-On/Off in the BIOS.
You would have to have a Wireless Router/Wireless Access Point in place already, it would need to be setup and security enabled.
Then it would be a matter of installing the driver for the device....WHEN you do that depends on the type of adapter you have:
add-on slot adapter -- Install adapter, then driver software
USB -- install driver software, DO NOT plug-in adapter until directed to do so, or the driver installation finishes.
Tallon41
Sep 18, 2012 | E-Machines eMachines Desktop PC
Cant get wireless to work on acer aspire ax3400desktop
Is it set up to be wireless? Is there a wireless card installed inside the desktop or are you using a wireless device that you use in one of the usb ports? Do you have a wireless router? Now that we've covered the basic requirements let's see if we can find a solution. Most desktops don't come with the ability to connect wirelessly out of the box. Normally you have to installed a wirelesss device either by using a pci wireless adapter that you istall inside the computer or a usb type adapter that you plug into a usb port. No matter which type you use you should have been given a software disk that contains the driver and the utility that controls the wireless device. You can connect either using the wireless utility software that should be on your desktop or under your programs list. Or you can connect using windows (windows comes with the ability to connect wireless once an adapter is installed) zero config. Normally your wireless utility software will have an option to either let it control your wireless connection or to let windows control the connection. I would try both options if I were you. Make sure you can see your wireless router in the list of available wireless networks. Find your network and click Connect. If it requires a password it will prompt you for it. Now if you notice your connection just continously polling trying to connect that means you put the password in wrong. You will never connect if you don't put the password in exactly right.
Mar 18, 2012 | Acer Aspire AX3400-U2022 PT.SE202.007...
Iphone doesn't recognize router
Check the wireless settings of your router. Make sure that Wireless SSID broadcast is enabled on your router.
If other wireless devices are able to see the network and only Iphone is not able to see the network then it might be the issue with the Iphone.
You can try changing the wireless channel on your router. You need to open the setup page of the router using 192.168.1.1 and change the settings.
Dec 07, 2011 | Linksys Wireless-G Broadband Router
Today I rearranged my router and unplugged it. Now upon plugging my router back in my wireless devices cannot find the internet. This includes my iPhone, iPods, laptops and a desktop computer. The internet...
It happened because the router automatically resets to it's default settings. Maybe you accidentally touch the reset button or the device was shaken to restore its default settings. Go ahead and check the router configuration. Or maybe the wireless switch of your router was turned off. Better check that as well.
Jun 20, 2011 | D-Link DIR-615 Wireless Router
I can access internet through wireless but cant access my iphone although it is conected with buffalo router but not accessing internet
I thought that the iPhone was connected to the internet thru IBM's cellular network, and did not
know how to talk to a wireless cable router at all.... note that the iPhone has no idea what
802.11n WiFi standard is... the iPhone uses 2 technologies to communicate with the AT&T network,
the iPhone 4G has two models, a CDMA model, and a GSM model...
IPhone reference: http://manuals.info.apple.com/en_US/iphone_user_guide.pdf
May 14, 2011 | Buffalo Technology Buffalo Wireless-N...
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
I MISPLACE THE INSTALLATION CD FOR MY WIRELESS G ROUTER, AND NOW I CANNOT INSTALL MY ROUTER.
A router does not need an installation cd for it to work. You could be referring to the manual cd that came with your device. Connect the router to your PC via LAN cable, and use a browser like IE or firefox to access the configuration system of teh router. Usually, you will type the address http://192.168.0.1 or http://192.168.1.1 to access the router. Please check the back or underside of the router for the correct address and account info to use.
Jul 16, 2008 | Belkin Computers & Internet
Netopia  2200 Series (2246N-VGX) Router (2246NVGX) Logo
54 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
