Cell Phones Logo
Anonymous Posted on Oct 31, 2011
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile uses) And shows full signal at the railway station which is near to my home. Where the problem is there? in the network ic? or in operating system?
  • Anonymous Nov 01, 2011
    thanks for the answer..
    I will describe very much clear below..
    They are the same models.. Actually My Mobile is Nokia 5130 Xpress Music
    I have two phones in my home of same model..
    The two phones have the same network airtel..
    But Phone1 gets signal when it is on the roof of my house and at the railway station..
    When i enter in the home with Phone1 it will get zero signal or 1 point..
    I don't know what is going on with my phone1..
    Where is the prob in the operating system or Network Ic.......
    In Past Actually i used this mobile(phone1) as modem in browsing for longer days in other place..
    this was not the condition of mobile(phone1) when i purchased 1 year before...
    Phone1 gets full signal when i climb roof(gets zero signal when i am in home).
    Phone2 gets full signal when i am in the home
kenneth njonjo
Level 3:
Top Expert:
  • Nokia Master 1,575 Answers
  • Posted on Oct 31, 2011
kenneth njonjo
Nokia Master
Level 3:
Top Expert:
Answers
1575
Questions
Helped
365735
Points
4558
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
3helpful
Hello Sir, I'm using Sony Ericsson J105i ( NAITE ) for past 10 months... In this phone network (signal) is weak for all operators.. i just use the same sim in other mobile . It shows strong signals... what...
there is a problem with the signal receptor chip... show your phone to some mobile expert on repair shop...... chip can be replaced...then it will work fine
My mobile is not getting network so what i want to
You cannot do anything for this problem.This problem is because of the structures around your home.The walls around your home is blocking/interfering with the signal coming inside and the mobile is unable to pick up the signal.
Please try this code
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. But phone battery will drain faster though.
*#3370* - (EFR) deactivation code
If it doesnt work then you cannot do anything else.
Thanx
Weak singal
plz change your mobile set
4helpful
My nokia n70 phone weak of signal
hi im josh in cebu phils.friend may i help you? your problem is weak signal. friend when the phone is weak signal there maybe a problem in hardware of the phone. the frequency reciever is weak im sure.but you can boost its functions throught entering the setting and go to network settings and select manual search.your phone frequency will search the network connections around so the hardware will be force to boost.once it will show the network providers around you select the network you are using and it will be setted to the network in more/ higher frquencyh signal. thats all friend hope i helped you.good luck/
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
2answers
Cannot get a signal on my nokia 6021
You need a new phone, water and electronics are not a good thing.
N91 Nokia
Improve reception in areas of your home or office where a weak signal is present with a Nokia N91 Cell Phone Signal Booster. Cell phone signal booster kits for your Nokia N91 cell phone amplify your wireless provider's frequency. Never miss a call and get rid of dead zones.
Weak (None) Signal Problem With Nokia N90
ok danish mein ne aap ki problen parkh le hai sab se pehle app apne moblie mein band setting cheak karein. aur ise try band par kar len.ya phir apne cell ki setting restore kar dein agar masnla hal na ho to phir dobara poch le zaror ,thanx
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
