If you're facing Such Issue then don't worry have a look, your solution is here
Try out any of these solutions to fix Canon Printer Error Code b300:
§Turn off the printer, disconnect the power cord from the electrical outlet. Now, you should hold down the power button for a minute. Then, reconnect the power cord to the electrical outlet and switch on the printer
§You can also clean the ink cartridges contacts to fix this error code
§You should open the printer, wait for the carriage to slide over. Then remove the ink cartridges and clean the print head with cotton swabs dipped in hot water. Once it is finished, allow to dry the print head and replace the cartridges.
If you still stuck then do visit this site: Canon Support Code 300
Toll-Free No: +1-888-633-7151
PLC Connection lost. Get your Oce technician to upgrade you to the latest supported software level.
SOURCE: Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
