Master
- Posted on Oct 31, 2011
Re: My back lights won't turn off on my toyota tercel...
Push the driver's seat as far back as possible, allowing you to lay on the floor on the driver's side.
Shine a flashlight at the top of
the brake pedal stalk and find the stoplight switch. It will be a
plastic cube either connected to the brake stalk or directly opposite
the brake stalk, depending on the vehicle.
Depress the brake pedal and feel
where the brake light switch contacts the stopping plate, a metal plate
in direct line with the stoplight switch.
Feel for an open hole where the
stoplight's plunger-style button presses. If a hole is present, you
simply need to replace the rubber stopper.
5
Press and release the
plunger-style button on the brake light switch and ask an assistant if
the brake lights are turning off and on. If not, the switch is bad and
must be replaced.
Stoplight Switch Stopper Replacement
Clean out any remaining debris left behind by the old stopper from the hole that the stopper goes into.
Press the new stopper into the hole on the metal plate until it snaps into place.
Shine the flashlight on the stopper and check that it sits flush against the metal plate.
Press and release the brake pedal and ask your assistant if the brake lights are turning off and on.
5
Replace the stoplight switch if the lights continue to stay on.
Stoplight Switch Replacement
Loosen and remove the bolts
holding the stoplight switch in place. It could be between one and four
bolts depending on the vehicle.
Pull the stoplight switch from
its mount. Disconnect the wiring harness from the stoplight switch by
pressing or pulling the locking tab and puling the harness away from the
switch.
Plug the wiring harness into the new switch until the locking tab clicks into place.
Place the new switch on the mount the old switch was removed from and tighten the bolts with a ratchet and socket.
5
Press and release the brake pedal several times and have your assistant check for proper operation.
