Hi!!!
try to replalced your strip
find in the surplus or computer shop center
the strip of your printer!!!
If you have problems with the encoder strip printer need to be serviced
What u can try is remove the ink cartridges from the
printer. Unplugg and replugg the power cable. Clean the copper contacts of the
carts using a dry paper towell. Snap the cart back to the printer and install
the cart as the new cart. Print the alignment page and if still have the same
issue it might be the issue with the encoder strip. Call Lex Tech Support and
get help to fix the encoder strip.
You can also try to download the updated drivers/software from here: downloads.lexmark.com
How do I fix the strip strip encore. Cleaning and taking out the cartridges did not do the trick.
How do I fix the encoder strip...the cleaning didn't do the job.
It shows system error 000
