B) Walking Belt/Motor Belt too Tight: If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3" without straining. Tighter belts should be loosen but make sure you don't create a dangerous slipping situation by loosening. The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt. http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
sincerely.
E. CUADRA
