When i power up my N95 it lights up and brings up the nokia splash screen that says "Nokia" , holds that screen for 3 or 4 seconds then goes black for the same amount of time then brings up the same same nokia screen again the goes black again the just keeps repeating that process over 3 or 4 times then just powers off again
You can go to any NCSP [Nokia Care Service Point] and get this done free of charge. If you email me your IMEI I can check your warranty for you. Also if you tell me your geographical location I will tell you where your nearest NCSP is.
Try to hard reset the Nokia N95 using the combination method.
Power off phone. Press and hold Green, * and 3 and keep them held whilst powering on and for a few seconds after, if kept pressed this formats without asking for Security Code confirmation.
<span>
<p>Nokia Became the Most Admired Mobile Phone Manufacturer and Most of the World mobile phone users have <a href="http://www.messiphone.com/mobile-secret/nokia.html">Nokia phones</a><br />But some models are more popular than others like N72, N73, N80, N81, <a href="http://www.messiphone.com/mobile-secret/nokia-n95.html">N95</a> and NSeries. <br />To fix some problems ( eg : get infected with virus, some system errors or installed too much software on it), many users asking me how to format Nokia NSeries Phone</b>.<br />
<p>So here are 3 ways method to format your Nokia NSeries cell phones<br />
<p><br />
<p><span>
<p>Method 1<br />
<p>1. Turn off the mobile Phone.<br />2. Press and Hold the following three buttons: Green Call Answer button</b> + the "*" button</b> + number "3′ button</b>.<br />3. While holding these buttons, press the power button</b> and switch on the phone.</b><br />4. When the message 'Formatting</b>' appears on the screen, release all of the buttons</b>.<br />
<p>Method 2<br />
<p>1. Switch off your Noki</b>a mobile phone<br />2. Now Press following key sequence *#7370#</b><br />3. Enter Default lock code is 12345</b>.<br />4. While holding these buttons, press the power button</b> and switch on the phone</b>.<br />5. Wait for message 'Formatting</b>' to appear on the screen and release all keys once you see that message.<br />
<p><span>
<p>Method 3<br />
<p>1. Switch off</b> the phone.<br />2. Hold down *#7780#</b> button.<br />3. While holding these buttons, press the power button</b> and switch on the phone</b>.<br />4. When the message 'Formatting</b>' appears on the screen, release all of the buttons.<br /></span><br /></span><br /></span>
In some models the above hard resets dont work then
press an hold "*","#","green" simaltaneously then power ur cell phone..after few seconds u ll see a formatting screen,it will take few minutes and ur cell phone will work fine
To master reset
go in settings and choose fone settings and do master reset
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones.
Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone. 2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key. 3. While holding these buttons, press the power button and switch on the phone. 4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone 2. Now Press following key sequence *#7370# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message. Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
Just format your phone by the following way
To Format the phone
1)Switch off the phone
2)Hold 3,* and Green button simultaneously
3)Now press the power button holding the 3 button, After 5 seconds leave the 3 buttons
4)You phnoe should say, formatting and all your data would be reset to factory orginal
CAUTION: You will loose all the data and contacts stored in phone memory, But this is the only way
There are two things that you could do. One is to power cycle the phone and to bring it to the Nokia.
To power cycle it, please follow the steps below:
1. Turn off the phone. 2. Remove the battery, SIM card and the memory card. 3. Leave it for about 5 minutes and then put everything back to the phone. 4. Restart the phone.
If same problem persist, bring it to the Nokia Care Center near you for possible firmware upgrade.
Nokia phones can be reformatted with a special three-stroke keystroke sequence on power-up. When turning the phone on, press and hold all these three keys at the same time: "GREEN/TALK" ," 3" and " * " when powering up the phone. When formatting begins, release the keys. Ensure the battery is fully charged.
man the code written is hard reset for n95 **** .there is a hardware problem in the cell phone you need to change the strip of ur cell phone which connect the upper and lower portion.
try to push and hold together buttons * ,3 and green handset then press power ( still holding buttons) . If it's not work you must do a manual software upgrade in service centre or someone who have special hardware for that. if you need that you can contact me at [email protected]
hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off. • Remove the battery, SIM card and memory card for at least 15 minutes. • Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*]. • Press the power button for 1 second. • Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
