This says it is easy to set up, but there is a Fixya post that says there are a reset button in both units. In mine, I have to put a new battery in the main unit and then remove and replace the button in the remote unit.
Anon, replace battery with a good strong AA Energizer or Duracell Alkaline not a cheap battery, make sure battery contact point in clock are clean and no corrosion. If this does correct the problem, the clock mechanism is probably just wearing out from age which is normal unless it is digital. Read through the links and learn how some time mechanisms can be made to work properly again. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to Maintain Battery Powered Quartz Wall Clock Save Money Quartz Battery Wall Clock Repair Fixing Disney Winnie The Pooh... Clock repair and troubleshooting
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
How to get sensor & Base to talk to each other
Need instruction for Epica WS-568 wireless weather station
need the instructions for the la crosse9740itc
