SOURCE: marco gas firplace
I also have a Marco fireplace with what sounds like the same setup as you. I've been digging for an owners manual myself for allowed clearances around the fireplace for wood mantles and such.
If the fireplace has a key valve it DOES NOT have a pilot. My fireplace has gas logs in it and I simply light a long match (or use one of those long necked stove lighting wands) stick it between the logs and turn on the gas. Make sure that the match doesn't extinguish as you poke it in between the logs (it may take 4-5 seconds before the gas lights up.) Also make sure that your flue is all the way open when using gas as your fuel.
SOURCE: Marco gas fireplace shuts off
This an easy fix. What you must do is remove the dust from the pilot safety. I use rust buster from ace hardware to gently flush the hole. If ther is no hole just shoot a tiny drop or 2 into the pilot burner where the flame comes out. Blow it out (I use a piece of tubing). The problem is the dust drops the pilot flame to a point where it won't heat the thermocouple hot enough to jold the magnet and after 30 minutes she quits. THIS is a picture of where to clean the ODS pilots in your rig.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: gas fireplace will not stay lit
there is a probe that is in the one of the flame... This once heated builds up enough pressure do to the heat to keep the shut/off valve open... (reason, if the flame went out the gas would continue to flow) this "thermocouple is replaceable !! contact me at [email protected]
SOURCE: How change a Marco Fireplace from wood burning to gas logs
HI best get as gas fitter in to look at this and see if it can be done safer bet
SOURCE: I have a Marco wood burning fireplace (Model
Go here and ask
http://www.marco-fireplace.net/Contact-Us.htm
regards
