My eos utility program will not recognize my cannon xti and I can't download my pictures. THis utility works fine on my computer that uses xp professional but my laptop has windows 7 and it doesn't work. what can do?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use the EOS utility or any other photo cataloging program.
Do you have a USB card reader? You can pick these up cheaply, and it is quicker and easier to take the memory card out of the canon and read it with the card reader.
I am not sure about this matter but it seems there is a problem with your new computer. it might not recognize the usb cable. try to plug your camera in another USB port and try again.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Seems to be a common problem with the XTi. Some say it's designed to underexpose to avoid washing out the bright parts of scene. Personally I found it a pita. I had to PhotoShop each shot.So I sent it back to the repair facility. They re-calibrated it. Now it works fine.
