Question about Power Acoustik 7 Widescreen Headrest Monitor"
Color stuck i have 2 five inch monitors the wires was cut so now im stuck trying to figure out what goes to what colored wire.There are 3 wires red-green-and white.The white wire isis double insulated so please tell me what each wire is used for.I know the red is for the power but which is for the yellow or white video and audio
3 Suggested Answers
SOURCE:
yeroc
  • 397 Answers
SOURCE: wiring problem
DO YOU HAVE THE PRODUCT # FOR THE MONITORS, I CAN PROBALY FIGURE SOMETHING OUT IF YOU CAN EITHER GET THAT OR SEND ME A PIC OF THE CONNECTION......COOL
Posted on Sep 17, 2008
the monitors are made by power acoustik there is a green wire a red wire and the white wire has a wire in the middle surrounded by ground wire8a804da.jpgd2d189c.jpg
THE WIRES TO MY EGR VALVE WERE CUT I HAVE A NEW PLUG BUT CANT FIGURE WHERE THE FIVE WIRES GO TO 02 SUNFIRE GT 2.4L
What color are the wires ? According to my service information that vehicle doesn't have any EGR valve . Maybe your mixed up with something else .
Mar 25, 2018 | Cars & Trucks
Have have a westing house switch no.77286 with a l123 and colored black yellow blue and white color wire which color goes to those no.
The black usually goes to the L. The others you'll have to play with, If it's the correct switch. You should mark down what color wire goes into which slot BEFORE you take them out. DO NOT CUT WIRES!
fanman9952@aol.com
Sep 18, 2014 | Dryers
I have a 2003 chevy silverado 1500, im trying to install an aftermarket radio. the problem im haveing is the factory wireing harness only has 11 colored wires. and no description. im how can i tell what...
DONT CUT ANY. Get an adapter from car toys or amazon etc. IF you do cut it, make sure you leave room to put it back on. The Chevrolet uses the radio for onstar and body information and you are in trouble if you make a mistake
Oct 30, 2017 | 2003 Chevrolet Silverado 1500
I have 1993 honda accord im try to swap a 2000 honda civic radio but my honda accord all we have for speakers cables are red blue green yellow and white,i can't figure it out wich one goes were the 2000...
All cars with 4 speakers have 8 speaker wires (4 positive and 4 negative). The colors of the wires for these two cars are not the same. The only way to know which wire goes where is to get wire diagrams for both cars. Before cutting up your wire harness, check that the radio you're installing will bolt into your car and fit. Just swapping the mounting bracket may not work.
Mar 12, 2011 | 1991 Honda Accord
Seats wires were cut, between the two front seats and also from the drivers seat to the panel. Need to know instructions to rewire
what u need to do is count how many wires are cut and will the wires reach eachother like do you need extra wiring to make up the differance all the wires are in colors like blue and red black and white 2 colors per wire some wires are a single colre ie blu blk rd yl match up youre wires to each other blu to blu red to red etc you will need **** connectors u can get at any automotive parts store or even walmart will have these u will need 1 **** connector per broken/cut wire all u do is strip the end of each wire about 3-8ths long slide one end into the **** connector and crimp that side then strip the other wire of the same color about3-8ths of an inch slide it in to the corresponding color **** connector
Oct 10, 2009 | 1995 Mercury Cougar
While attempting to change stereo on my volvo 940 turbo I cut wire harness now headlights wont come on
ok that problem is where u cut the wires on the rdaio harness u cut is a dimmer wire for your lights on the radio need to figure out which if u have a autozone or advanced parts store they have a radio wire harnes kit has all color code and wire color tells what goes where and what the wire is for
Oct 05, 2009 | 2007 Avanti Convertible
Trying to get the color codes for the speakers wires someone cut my radio wires and im trying to install new one.
Usually speaker wires have a solid color, and a stripe of another color on them. Sometimes it's a solid color, and rings going around the wire of another color.
The striped wire is the Positive. Then there will be a wire, that is the same color as the stripe. (On the striped wire) This is the Ground wire.
Apr 29, 2009 | 1989 Mercury Sable
ACER AL1715ebm LCD MONITOR BAD VGA CABLE
you are in a bad spot, the plug is sealed when molded. maybe ebay has a defective monitor and you could take the cable off it.
Monitors will usually snap apart with a butter knife.
Jan 27, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Colors not distinguishable
Is your monitor by any chance sitting next to unshielded speakers or anything else which could generate an electomagnetic field? You can get some terrific colour shifts with these items. If you do have anything like this put some distance between them and the monitor. Also the auto degauss coil circuitry could be faulty in the monitor. Take it to a repair shop and ask the tech to degauss the tube and see what difference it makes. If it fixes the problem get him to check the degauss system. Don't try this yourself. There's lots of voltage running around inside a TV. Fix don't Fry BMW
Jul 01, 2006 | LG Studioworks 45 14" CRT Monitor
Power Acoustik 7 Widescreen Headrest Monitor" Logo
37 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
