Master
- Posted on Oct 29, 2011
Re: Ink cartridge doesnt any help
- Make sure the HP All-in-One is on. Press the On
button to turn on the HP All-in-One. The On
button is lit when the HP All-in-One
is on.Figure 1: Press the On button to turn the product on1 - On buttonCAUTION:If the HP All-in-One is off when you open the print-carriage
access door to access the print cartridges, the HP All-in-One will not
release the cartridges for changing. You might damage the HP All-in-One
if the print cartridges are not docked safely on the right side when you try
to remove them.
- Open the print-carriage access door by pulling it forward.
The print carriage moves to the far right side of the HP All-in-One.Figure 2: Openink cartridge doesnt any help - c00442143.gifoor
- Wait until the print carriage is idle and silent, and then lightly press down on a
print cartriink cartridge doesnt any help - c00316910.gife it.Figure 3: The print carriage
- If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
- If you are replacing the black or photo print cartridge, remove the print cartridge
from the slink cartridge doesnt any help - c00442144.gifht.
Figure 4: The print cartridges in the proper position1 - Print cartridge slot for the tri-color print cartridge2 - Print cartridge slot for the black and photo print cartridges - Pull the print cartridge toward you out of its slot.
Step two: Install the new print cartridgeBack to top- Remove the new print cartridge from its packaging and, being careful to tink cartridge doesnt any help - c00442146.gif black plastic, gently remove the plastic tape by using the pink pull tab.Figure 5: Remove the tape1 - Copper-colored contacts2 - Plastic tape with pink pull tab (must be removed before installing)3 - Ink nozzles under tapeCAUTION:Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
- Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
- If you are installing think cartridge doesnt any help - c00442148.gifrint cartridge, slide it into the left slot.
- If you are installing a black or photo print cartridge, slideink cartridge doesnt any help - c00442149.gifright slot.
Figure 6: Insert the print cartridge - Close the print-carriage access door.Figure 7: Close the access door
Step three: Align the print cartridgesThe HP All-in-One prompts you to align cartridges every time you install or replace a
print cartridge. Use tink cartridge doesnt any help - note.pngwing steps to align the print cartridges from the control panel.- Make sure you have letter or A4 unused plain white paper loaded in the input
tray, and then press OK
- The HP All-in-One prints a print cartridge alignment sheet.NOTE:If you have colored paper loaded in the input tray when you align
the print cink cartridge doesnt any help - c00443602.gife alignment will fail. Load unused plain white paper
into the input tray, and then try the alignment again.
- Lift the lid. Place the top of the alignment page face
down in the left front corner of the scanner glass. Close
the lid.Figure 8: Load the alignment sheet on the glass
- Press OK
to begin the alignment.
- The HP All-in-One aligns the print cartridges. Recycle or discard the print
ink cartridge doesnt remove from its slot i need to refill it any ideas of how to take it out ?????????? please
