This can be the MAIN power supply in the protect MODE as it is possible that there is a short within in the driver sections. You need to be equipped to check as it involves isolating the circuit, check the + B to the related circuits . Check the SMPS, remove the connections to the main board and see if the voltage build up . If so you cane proceed to isolate the circuit which seems to short the power supply. check for heating components which can indicate a fault.
