Nokia E52 Smartphone Logo
umesh Mohod Posted on Oct 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I went to 3g setting my nokia e52 hand set - Nokia E52 Smartphone
Anonymous
Level 3:
  • Nokia Master 356 Answers
  • Posted on Oct 28, 2011
Anonymous
Nokia Master
Level 3:
Answers
356
Questions
0
Helped
47898
Points
1199
Call your service provider for the 3g settings .they will provide it for you.
good luck
Sunny Solanki
Level 2:
  • Expert 264 Answers
  • Posted on Oct 30, 2011
Sunny Solanki
Expert
Level 2:
Answers
264
Questions
Helped
38877
Points
899
There is nothing like 3G settings.Your 2G settings will work when you use 3G network.The only thing in 3G is network of 3G.
Required capibility not granted of nokia e52
in configuration setting ,make a new setting like add new select multimidia and select
1helpful
I buy new nokia 52 . I want chenge nokia E52 language to chinese !
To change the language on your Nokia E52 do this: Select Menu > Ctrl. panel > Settings and General > Personalisation > Language > select Phone language > select Chinese. Hope this helps!
Apr 10, 2011 • Cell Phones
2helpful
1. How Can I Use Second Camera In 3g Video Call 2. How Can Support 3g Signal In My 5230 Hand Set
hello there!
You have to contact your Network Provider in regard with the settings to enable the use of 3G services on video calling.
Regards,
fossildude
3helpful
My unit is Nokia E52.please help me how to deactivate power saving mode because i can't change my light time-out due to power saving mode active.
As Nokia E52 is the ESSENTIAL MODEL Mobiles, As its in high Range of Applications Used to get it's Visual.
Here are the Fiew tips to DEACTIVATE the Power Saving Mode.
1. First Switch on your Mobile.
2. After completing it's Process, Click the Menu Button.
3. Go to the Settings
4. Settings -> Display Settings
5. Go to the Power Saver Mode Option,
6. Change the Mode of Operation from ON to OFF
7. As Now go to the Screensaver Settings,
Change the Time-Out time to your Favour.(Not Less than 15 Secs)
7. As after this setting is Done, Restart you Mobile Phone
But Kindly Connect your Phone with Nokia PC Suit and Update your Phone to keep your phone upto date of the Latest firmware.
To get the Updater, Click the Link Below
http://www.nokia.com.sg/support/download-software/phone-software-update
Click the Download Button in Update using your PC section, There you can find Nokia Software Updater, Select your Language.
1helpful
E52 internet pc setting for mtnl
BELOW ARE THE SETTINGS
How to set GPRS settings for your phone (In case Postpaid) Name of Service: mtnl_wap APN: gprsmtnldel IP Address: 172.16.31.10 Port Number: 9201 Homepage: http://172.16.31.23:8181/mtnl/index.wml Username: mtnl Password: mtnl123
How to set GPRS settings for your phone (In case prepaid) Name of Service: mtnl_wap APN: gprsppsdel IP Address: 172.16.31.10 Port Number: 9201 Homepage: http://172.16.31.23:8181/mtnl/index.wml Username: mtnl Password: mtnl123
Whenever someone calls my nokia e52 just blinks but it does not ring. Is this comon problem of this tipe
Only if you have the ringer turned down or off ... set the ringer volume. If this doesnt work ... call your service provider.
3helpful
How do I change the language of a Nokia E52 from German to English
1) Press menu button, then press 4x ok (center) button, then 4x down, then ok 2x, you reached the Language menu.
2) Go to Menu/Control Panel/Settings/General/Personalisation/Language/Phone language/English
Nokia E52 - Tone settings
of corse. see in settings (may be in sound or profiles)
1helpful
Nokia E52, freeze with Answering Machine Adv. Call Manager
i am also having the same problem in my E72-1 FV 052.005
marco_petill if you have found something then pls let me know i need this software desperately...
thanks in advance....
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
