My 36 months old LTV30C gave up, it wouldn't turn, it seems the adapter is dead.. where can i buy a new adaper please? .. please advice My 36 months old LTV30C gave up, it wouldn't turn, it seems the adapter is dead.. where can i buy a new adaper please? .. please advice
You can't post conmments that contain an email address.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue. try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging. Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter. You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
thats what i suggested earlier, the AC adapter in the laptop has blown, thats what causing the feedback/overload. you can fix the problem yourself but it is a big job!!! If you need the problem resolving straight away, then take it to be repaired, under warranty if its still covered by it!! Sorry for the misunderstanding
Hi...there,
A simple way to check your AC Adapter, plugged into a socket and see if it lite green... If you don't see a green light lite on the AC Adapter, then it's DEAD... You can order the AC Adapter @ www.3rd-rocks.com but sometime you need to replaced both. Have a nice day!
Yes with an LCD it can be dead. The life of LCD is not nearly that of a tube TV. It depends on the hours of use. Most likely time to replace it. Good luck, Lee
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Check the ac adapter is the proper one for that laptop.
Check the power jack is not damaged or loose.
let laptop site without battery or power for a few hours.
remove battery and retry power.
try another ac adapter
if that doesn't work, you may have a reset button but not likely to solve the problem.
sounds like motherboard is damaged, or something blew.
