The F25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then re-seat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
