SOURCE: Nextra Hoover Fridge Freezer, Fridge not cold enough.
I would turn the thermostat up towards number 4.
SOURCE: the fridge part of my fridge freezer keeps freezing everything,
I tried solution 1 without success, so I resorted to switching the whole unit off at night and on in the day to stop it freezing up. After about a week of doing this it started working properly again. One month later it is still OK
SOURCE: hoover contour fridge leaking
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Testimonial: "thanks, all fixed!!"
SOURCE: hoover a class fridge freezer, freezer keeps icing
You have an auto defrost problem. Need to check element for resistence. if good, check the thermal fuse for continuety. Most of the time i replace both the thermal fuse and the little clixon that is attached to the evaporator coil. Defrost timer is quite robust and very seldom do i need to replace that. You need to firstly defrost freezer overnight to allow cover removal. All components should be visible.
SOURCE: freezer getting cold but not freezing food
..I'm not certain here but there are a couple of things we can look at and diagnose. First, be sure that your doors close tightly. If the gaskets leak, this will allow humidity in...that's where ice comes from. If you 'windowshop', this will also cause icing. Now...let's start with a full defrost. This can take about two days with the unit open and off. Once accomplished, the next thing to do is look at the unit itself. First, underneath, is the condenser coil clean? If not, do that. Now, from the back, remove the felt panel covering the lower portion. The big thing is the compressor. If the unit has been off for more than 20 minutes, clean the big pipe off. Now, start the unit. It should develop frost on the pipe which should either freeze up or dry out after 5 minutes or so. Caution: there is a fan in there! If still frosty, you're low on gas and the unit probably has a small leak. The icemaker can be looked at by removing it. It contains a float. If the float is damaged or jammed, it will not shut off...and will overfill the icemaker. Good luck.
