Hello, welcome to FixYa.
I understand you have the Frigidaire CFEF372ES1 range, correct ? I also understand based on your post you're getting the F13 error message, correct ?
This range is built by Frigidaire as you know and according to their service manual, here's what it is and what you can do
...I will also add, **Fault codes are not a foolproof system. Never assume that a part has failed based on a displayed fault code. **
...If you pull/slide the unit away from the wall and unplug it or turn the house breaker off for 30 seconds to a minute the control should reset. That should do it...unless the EOC (electronic oven control) has failed.
Let me know how you make out and if you need anything further I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
Hello Carol Martin - Typically, error codes F10 and F13 could indicate a variety of issues. The range could possibly have a shorted keypad, runaway temperature (higher than normal temperature), faulty EOC (electronic oven control) or, display wire harness missing/not connected. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
