Both the tv and the Bush HD freesat box was bought in the Euoupean union?Wright?Yes,it will work together with no problems,both the tv and Bush HD freesat box both are recieving the same tv incomming broadcasting signal in PAL signal frequencies will be compatible.
Thanks for your reply. Am i doing something wrong then? I plug the HDMI cable to TV and Bush HD freesat box and the sattelite cable to freesat box but it shows 'no signal detected' . I don't have a remote control for the TV but i didn't think this would make any difference. Is there anything else i should be doing?
Thanks
I forgot to add that the TV was bought in the US.
Sorry tvs that are bought in the US,Canada and Mexico are receiving in NTSC signals frequencies only for the tv incomming broadcasting tvs signals.Tvs that are bought in Asia,European Unions,Australia,Africa and the Middle East are receiving in PAL signals frequecies only for the tv incomming broadcasting tvs signals.Sorry not compatible Equipments.U should of bought a tv that are called A Regions Free Tv,this tv can be used all over the world continents.
No,sorry tvs are a very complicate electronic circuitries equipments and have many boards and components parts involved with many parts like transformers,transistors resistors and ICs are involed with many patented works of each of it own countries and programming softwares.That why the tvs industries compromise and develope a tv that call the Regions Free Tv.This is the only way,that why the Regions free Tv was developed for to be used it without lands borders.
Looking at the back of this Westinghouse tv it says '50/60 hertz. Does this mean that it will receive channels in Europe (50h) as well as the US (60h)?
Thanks
How can i be sure that the tv is in NTSC as there is nothing on the back stating this but it does show 50/60 hertz. What does this tell me?
Thanks
Back of the tv.It have a label have the tv spec. and the tv regions it to be as NTSC or PAL regions tv to be used in.
No,ur tv HDMI inputs ports in the tv Tuner signal board might or must be all dead,if u still getting nothing.This happens alot when u tries too many times like plug in and take out trying of all of thoes HDMI ports hubs trying to getting any tv signal on the tv screen incomming signal,those HDMI inputs ports hubs are very sensitive to low static charges of electricity.One HDMI port hub is dead they all dead,all these HDMI ports hubs are link together as one path connections onto a circuit board. Dose the scaler box have AV cables connections cables connections like Yellow,Green,Red, White.Tries connections av cable connections to the tv and the scaler box.AV cable connections should do the same things for as a HD signal just more inputs AV cables.
The scaler box doesn't have any other ports other than HDMI and audio. If i return the box and get one that uses AV cables could this work - just not in HD?
Thanks. Is it possible to change the frequency of this tv to work in te uk?
Hello - me again! I've now bought a HDMI scaler box to convert the NTSC signal to UK pal. I still can't get anything - it still says 'no input signal'. Is there anything on the TV settings which could be stopping me receiving anything. I've set the input to HDMI 1 (and tried all the other ports 1-4) Do Westinghouse have a setting that needs changing over or switching on?
Thanks
