KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
m. margolis Posted on Mar 02, 2017
Same problems - Kitchen-aid microwave goes on by itself, locks, beeps, f2 error - rediculous! 4 of my 5 appliances have problems -big problems. The free standing oven has a "hardly working" keypad and to turn the oven on I have let the broiler heat up,then enter a number for the degrees and to turn it off I have to set the timer! I cannot use the self-cleaning function because the oven door locks and a $$service call and part$$ is required for the oven door to open again! Did I already say rediculous? I meant rip-off! The door hinge on my fancy dishwasher is broken as well. I wonder how long the deep-bruise down my leg will take to heal... Wowww - heavy door!(maybe that means quality?!) The icemaker on the frig lasted about 6 months. I buy bags of ice to put into my fancy/shiny freezer - paid extra for the "reduced depth" model. All bought in September of 2005. And now a wholehearted thank you to Kitchen-aid for their incredible dedication to safety and quality and the ability to squeeze our hard-earned money from us. Oh yes, please note some other threads regarding oven doors and how the glass explodes, for no obvious reason, when hot or room temperature - doesn't matter. Blah, Blah, Blah.... sure like the stainless though...blah!
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 26, 2007
SOURCE: Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jun 11, 2009
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Anonymous
  • 125 Answers
  • Posted on Aug 20, 2009
SOURCE: kitchen aid microwave KHMS155LBL2 showing up
first is it under warrenty? if so take back. if not and you want to fix it yourself: how much did u pay. less than $200. maybe trow it away and buy new one. if u paid more and r fixing it yourself, then unplug it from the wall, wait 60 seconds or more then plug in, check display only. do this and respond for more help.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 29, 2009
SOURCE: microwave oven door heavy
If one of your door springs has failed, you will need to replace both, as well as any associated hardware that has failed.
You can find links to helpful exploded view diagrams and part ordering help here.
Anonymous
  • 906 Answers
  • Posted on Jul 31, 2010
SOURCE: F2 Message Code
good day,
hope this link below will solve your problem.
kitchen appliances
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
1helpful
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
1helpful
Microwave Model KHMS155LWH3 is showing a trouble code F-2 What does it mesn?
F2 is saying the key pad has a problem:
See this tech sheet:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208205612.pdf
The touch/keypad can be found here: (Item 9) BLACK
I am assuming yours is white but the model number does not cross for some reason to a white control panel. When I cross it to your model it comes up Biscuit color ITEM 3 here:
($122.18)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133020&diagram_id=948095#d948095
I would check to make sure that no keys are stuck by rubbing your 1st finger FLAT across the membranes to unstick them and then check inside the unit to make sure the flexible ribbon connector is properly mated to the control board. Inside the unti there is usually a tech sheet inside the cabinet stored in a 4 X 6 envelope that may give you some insight on the keypad error. It should be Item 1 here as far as location only:
Thanks for choosing FixYa.
Kelly
3helpful
Microwave is beeping, lock comes on, F2, just keeps beeping by itself
F2 on a KitchenAid mike usually means a Keypad short. Beware if it is a KHMS155LSS, it can self start on its own with a KeyPad short. A real stunning defect.
1helpful
Kitchen aid microwave KHMS155LBL2 showing up locked and then showing F2. It keeps beeping. Now it won't let you do anything.
F2 Message Code
good day,
kitchen appliances
7helpful
2answers
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
