Kirby Ultimate G Bagged Upright Vacuum Logo
Used shampoo attachment and now it won't start at all, new vacumn and I am not sure what is wrong.Senteria model and it is the first time i have used the shampoo attachments.
5 Related Answers
Anonymous
  • Posted on May 28, 2007
SOURCE: Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
b0sslady2001
Marci Marple
  • 357 Answers
  • Posted on Oct 25, 2007
SOURCE: kirby utlimate g
Here is your help....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Anonymous
  • 310 Answers
  • Posted on Apr 23, 2008
SOURCE: I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
Kirby G5 Bagged Upright Vacuum
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
b0sslady2001
Marci Marple
  • 357 Answers
  • Posted on Jun 22, 2008
SOURCE: how do i use the
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier.
Instruction manuals available in DVD, VHS or book format by following this link,..
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Hope this helps...
b0sslady2001
Marci Marple
  • 357 Answers
  • Posted on Jan 29, 2009
SOURCE: Kirby Ultimate G Series carpet shampoo attachment.
TRY MY FREE ONLINE MANUAL....
HOPE THIS HELPED...
MARCI
I have a Kirby G6 and carpet shampooer won’t foam or produce even foam / water - I have tried : Soap sue plug is in place Sponger filter in place neither of these parts are clogged . Attached correctly...
If you are using the correct shampoo then the tank my need to be replaced. They will clog if tank wasn't cleaned after last used. Check that the dial is open and both filters are in place , add water and shampoo and test without the hose connected . If you still have no suds coming out then just order a new tank.
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Wertheim w2550 carpet cleaner won't dispense shampoo
I just bathed my dog with sergeants skip-flea & tick shampoo with 0.10% permethrin and 0.50% piperonyl butoxide, technical. My dad then proceeded to almost immediately after apply another flea ...
Sep 07, 2012 • Vacuums
How do u remove the bag to make it a shampoo
You can unclip the bag at the top where it attaches just below the handle. The base of the bag actually turns and screw off. Turn the bag outward and lift off. Then fill the shampoo attachment and screw it on just as the bag screwed off. But make sure you attach the shampoo brush and attachment. Can't use the regular power head. The video is pretty helpful if you still have it. If not, try Utube
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 • Vacuums
3helpful
2answers
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
How do I put my vacumn together? No instructions included!
vax 2000 how do i use this as a wet vacuum cleaner or shampoo
this is a 1999 model
5helpful
Shampoo stairs
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture/stairs thoroughly before shampooing. Cover the stairs/furniture with a thick coat of suds. Once covered with suds, pop the suds into the fabric/carpet using your hands...working the bubbles into any heavily soiled areas with a soft brush. No need to vacuum after shampooing. There is only about 10 percent water to 90 percent air in the suds.
Then let it dry. 15 minutes to and hour depending on the amount of solution used. Hope this helps!!!
36helpful
2answers
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
