Philips 42PF7320A 42 in. Plasma HDTV Logo
Posted on Sep 24, 2008
Blue ghost there is a blue ghost it appears to have a blue double image i have tried all the adjustment buttons and nothing has any effect is there an internal adjustment or could it need a part
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
221
Points
I have blue ghosts/shadowing at the top of the screen.
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
5answers
Ghosts
How old is ur tv...? Cos the wear & tear is the cause for this ghost appearance. The repair for this is only temporarily. It can not be eliminated completely.
Generally the blue ad yellow colour can be removed by a tool which is available with a tv technician. It is not very expensive to do this. Hoping to hear from you.
Thankyou
My zenith sentry tv has a double image on the words that come on screen. The people are clear but all wording has double images
Hello
Double images are technically called Ghosts, occures due to the setting and direction on the antena. You have to reorient your antena, in such a way that Ghosts disappeares from your screen. The reson for this fault is not with the TV, as it gets a direct transmission signal, and a reflected signal of the same, reflected from near or far objects, like tall buldings, hills and so on. The signals, the orginal and the reflected, will be processed by the TVs internal ciiruit, and the first will appear as strong picture, followed by the second, a weak picture, will be seemed as an image of the first one, just on the right side [view point] of your TV.
You just adjust the position and height of your antena, looking the picture, where there is minimum Ghost level is. No other repair should be done to your TV, as it is perfect, and you just give it only direct signal path. OK.
Samsung SP43T6HCX displaying ghost images
May be it is effected with a virus
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
1helpful
2answers
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
1helpful
2answers
Picture has a shadow (double effect)
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
2helpful
2answers
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
