SOURCE: Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
SOURCE: How do i save screensaver images to my power acoustik PTID-7002NR
You need to upload then via USB. You should have a cable that came with your unit
I HAVE THE SAME PROBLEM WITH MINE CAN SOMEONE
PLEASE HELP THANKS
