SOURCE: lithium batteries?
Just got a reply from Ryobi tech service and it says that "all Ryobi 18V platform power tools can accept and use the lithium batterys, but you must use the charger for the lithium to recharge them. Hope this helps. Dave
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
something is wrong. take it back if possible.
SOURCE: my new 18v lithium batteries run out of charge
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Testimonial: "thanks wll give it a try out"
SOURCE: I bought the two pack
I would not say they are not defected, but I think they are not getting fully charged. I have the same problem with my battery once I have used it all day and the red light comes on from the fuel gauge. I have the P104 battery. I would return your charger and try to charge them on the new one first. If you have the same trouble, then return the batteries for new ones.
SOURCE: WHY DO NEW LITHIUM 18V BATTERIES CUT OUT UNDER
Did you check the charger?
If you need more help post back!
Thumbs and testimonial are welcome!
