SOURCE: Need to replace band on Relic ZR50003/1200607 watch
Hi i need to change the band in my watch any idea how to do it ?
Many Thanks
Wiola
SOURCE: finding replacement watch band
Hmmmm to get an orange rubber band you will more than likely have to go thru Bvlgari. I have access to a lot of watch band but I have not seen an orange rubber band in any of the catalogs I get. You can contact them at 1-800- BVLGARI
SOURCE: I just bought a Haurex watch with the white rubber
Go back to the supplier; If you cannot get the clasp to work, you should be shown how to operate it (or it should be replaced if it is broken).
SOURCE: Replacement watch band
You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
Testimonial: "Quick and informative response!"
SOURCE: My Casio watch band has split apart where the
are you referring to casio mtg900 if so do you mean the rubber part below the G button . If so I do believe casio sells that first link . You can call them if you would like to order it if they still have in stock or for a whole new band
you can see the parts store here
http://www.pacparts.com/model.cfm?CFID=3663724&CFTOKEN=19469938&mfg=CASIO&model_id=MTG900DA-9V&row_start=1&src_model_id=mtg-900&action=list_part
I believe the 12 h and 6 h are the parts you are looking for I am not sure what side you need 12 oclock or 6 oclock , but give them a call they should be able to help you out
the other company that handles watch parts is here
http://www.americanperfit.com/parts/parts.htm
